I have a DieHard battery, not sure what vehicle it was sourced from, that I have been keeping on a trickle charger for years. Date I wrote on the battery was 10/14. I use this as a standby battery, bu...
My winch is fairly small since I have light weight cars and I use it only a few times per year so I don't have a dedicated battery. I use an old jumper battery box that I have had for 30 years or so and just keep replacing the battery inside every 5 to 10 years. It has an ExpertPower EXP12180 12V 18Ah Lead Acid Battery in as of 2 years go. It runs the winch and gives me a 12 volt battery for other uses around the shop, I just plug it in after a heavy use.
Having RV issues? Connect with others who have been in your shoes.24,213 PostsLatest Activity: Mar 13, 2025
