DiskDoctr
Apr 23, 2017Explorer
mchero wrote:
This is what I was told. The communication cable between the 458 and remote use a 2 pair reversed cable. A 3 pair reversed cable (6 conductors) will work, it just does not use the outer pair.
Reversed cable. By pair like a cross over cable, or in sequence?
Option 1: 1234 = 4321 would reverse inside pair and then reverse outside pair
or
Option 2: 1234 = 4321 is a straight sequence reversal (not a tech term)
I'm looking to remote my control panel on the PROSine 1800w. It's used and I'll have to make my own cable.
Sorry I can't help you with your problem, but the info can sure help me ;)
Thanks.
