mthunter66's avatar
mthunter66
YAMAHA Propane Generator
I just bought used camper that comes with a Yamaha EF2800I generator
that runs on propane. has anybody used one for camping. Any tips or advice appreciated. If I don't like it I will try to sell it and get 2000 watt gas
hank you
  • wa8yxm wrote:
    I thought the 2,000 watt unit in tha tline was an EF-2400i, but.. I won't discount the posibilty of a 2800.
    That is an excellent generator, Though I have not used one myself I have seen them and looked at them, IF I were to purchase a portable the EF-2400i (Gasoline) would be my #1 choice.
    As for propane v/s Gasoline,, Propane should make it a bit less noisy (And this is a generator that is already less noisy) and easier to start since unlike gas Propane does not "Go bad"
    In short, I think you have a great generator there.
    NOW.. the only "Problem"
    IT may suck a LOT of propane... I mean a 20 pound bottle is what 4 gallons when filled (about) to the cut off point... and that's perhaps 3.5 gallons of Gasoline equivlent. So you may need to refill the propane tank a bit more often than you are used to.
    But I sure would not turn down one of those.
    EF2800i link............
    I see it does have the smart throttle, which I would guess has to be turned off when running on propane/NG.
  • wa8yxm's avatar
    wa8yxm
  • dbbls wrote:
    Your 2800 watt generator will make about 2500 watts using propane. I had a propane Onan generator for 9 years and never experienced the problems that "mexicowander" describes. It was trouble free all of these years.
    This is a typical quote often repeated. I can tell you first hand from test that I can produce full power from my Yamaha on Natural Gas and Propane. The small Yamaha generators have enough excess HP to over come the lost of power.
    I suggest you go here, these folks are approved by Yamaha to convert their generators link................
    From their FAQ section:
    Is there any power loss when operating on alternative fuels?
    No, we have never had a single unit show a loss of power on alternate fuel. Though lower gallon-to-gallon in BTU content, sometimes they perform even better than running on gasoline (see also fuel consumption). The engine regulator we install has an external fuel mixture adjuster that can be turned with your fingers and can be fine-tuned to your elevation and to the fuel supply connected. That's why we include the Engine Hour/Tachometer Meter with every generator. You can watch the engine rpm output while turning the mixture adjuster for peak performance and high efficiency. This allows full control over the fuel mixture no matter what elevation. Unlike operating on gasoline where the carburetor is a fixed jet and it can not be adjusted only replaced. This is a big advantage that allows the engine to be reset at anytime. Engines would not use the same fuel mixture in different areas especially as diverse as say Florida would be to Colorado. Unlike gasoline, setting the mixture lean on alternative fuel is cool running, clean burning and efficient."
  • Your 2800 watt generator will make about 2500 watts using propane. I had a propane Onan generator for 9 years and never experienced the problems that "mexicowander" describes. It was trouble free all of these years.
  • Welcome.
    A word of advice.....
    RV.anet prohibits posting the same thread in multiple categories.
  • Three operating issues I noted with LPG gensets...
    1. Expect about 80% total power from the engine
    2. LPG engines operate significantly hotter than gasoline engines.
    3. Weird City: LPG engines develop more lube oil gasket leaks.
    The cons and pros are extensive. Greater gallonage fuel consumption, fuel harder to find, remote. Containers are heavy and bulky. Engines run cleaner, fuel never goes bad, no fuel pump, spark plugs last much longer, oil stays clean like new.
    Suggestion: Review the above, keep the points in mind (especially the positive ones) use the generator and come to your own conclusion. No one can decide this but you. Don't let anyone else "decide" for you.
  • MM49 wrote:
    It sounds like a nightmare to me. Inverter generators are very sensitive with several mechanical and electrical feedback mechanisms working all the time. Adding propane to the mix will be very difficult to control. I wish you the very best luck.
    MM49
    What?? do you know anything first hand about that generator? like it might be a constant speed generator?
    I have the EF2600 and it runs great on propane, natural gas or Gasoline. I have used all three for over 250 hrs.
    I would think that generator is a tri-fuel conversion, unless someone did the bi-fuel conversion.
  • It sounds like a nightmare to me. Inverter generators are very sensitive with several mechanical and electrical feedback mechanisms working all the time. Adding propane to the mix will be very difficult to control. I wish you the very best luck.
    MM49
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 09, 2026
