richy2's avatar
richy2
Jan 12, 2018
Zamp solar alternative
I have a small motorhome equipped with 2 agm group 27 batteries, Zamp external port and 1000 watt inverter. looking for alternatives to Zamp suitcase type solar panels. I have minimal power needs, two or three hours of tv and some led lighting. I do not want to void warranty, so compatibility is important. Thanks for suggestions.
Based on the questions, I'll try to be more clear. I want something portable as in suitcase type not roof mount. The port is sae. Compatibility means working with equipment I have mentioned. Will need controller.
Based on some of the responses, I guess I'm still not clear. All that I need is a portable solar panel to work with a motorhome that is Zamp solar ready, meaning it has a SAE port mounted on side of motorhome. What manufacturers other than Zamp can provide what I'm looking for, hopefully at less cost.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
