Krusty
Nov 06, 2023Nomad II
I agree it is likely a corrosion related issue and you should inspect the trailer connector and the wiring that connects to it. Not sure what modules you were able to read with your code reader, but typically they are only good for the PCM, so there could be several other modules with faults that you are unable to detect.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.206 PostsLatest Activity: Mar 15, 2025
