โJun-12-2023 12:52 PM
โNov-12-2023 09:57 AM
โNov-11-2023 05:33 AM
โNov-21-2023 08:02 PM
Why on earth would you run that high of pressure? Thatโs just silly.
But your rims will be fine. Not sure why that other feller is worried about that.
โJun-13-2023 12:40 PM
fallsrider wrote:valhalla360 wrote:
Is it a 1/2 ton or 3/4 ton burb?
What are you towing and how heavy is it?
If you are towing a 2000lb popup, it really doesn't matter.
If you are maxing out the tow rating on a 3/4 ton, you definitely should get the beefier tires.
1/2 ton 'burb
Trailer: 1995 Sunnybrook 26 DB. I haven't weighed it, but the dry weight is rated at 3,900 (meaningless, I know), so I figure I'm in the low 5,000 to 6,000 lb. range, (7,000 GVWR). I weighed the tongue with a full FW tank (it's as far forward as it can be and holds 42 gal.), and it was 710. I typically keep the FW tank around 1/2 full.
โJun-13-2023 11:23 AM
1/2 ton 'burb
โJun-13-2023 11:01 AM
โJun-13-2023 08:27 AM
โJun-13-2023 08:21 AM
โJun-13-2023 07:26 AM
โJun-13-2023 07:10 AM
phillyg wrote:There seems to be a consensus on Load E LT tires. Thanks.
I would only use E-rated tires on that vehicle.
โJun-13-2023 07:08 AM
NamMedevac 70 wrote:Thanks for the info. I've never bought Hankook tires, though I'm aware of the brand. I'll have to look into them.
For many years I have used only LT tires on 3 Dodge Ram 1500 and 2500 towing a 28 foot TT. Tires were goodyear, BF Goodrich and Michelin.
Now I run Hankook Winter Pike P275/60/R20 116 XL with T speed rating on a 2014 Ram 1500 4x4 that is heavily loaded with full camper shell heavily loaded and there is no squirm at all from the tires in the Sierra Nevada Mountains and even in recent harsh winter snow ice slick road conditions on steep up and down grades and sharp curves. Speeds between 55 and 75 mph. I would feel very comfortable towing a small TT with these tires.
Hankooks are great and Walmart gave them to me (set of 4 plus new full size spare) for 400.00 because original customer would not wait for store delivery. My good fortune. I also still have the new all-purpose tires that came with the truck with only 4 or 5K miles on them. Life is good.
โJun-13-2023 05:31 AM
โJun-13-2023 02:49 AM
โJun-12-2023 05:33 PM
ktmrfs wrote:Thanks. That's probably a good way to look at it.
Personally I'd never run a P tire on a burb, full size van, or pickup. Yes, they may ride better, but they won't handle the "squrim" with a loaded vehicle or towing near as well as a E rated LT tire.
When we bought our full sized 3/4 ton van in the mid 80's I didn't put 10K miles on it before off came the P rated tires and on when LT 15" tires. Much more confident handling.
My S-10 also came with P rated tires and they didn't stay on long either.
My $0.02 worth
