Onyrlef's avatar
Onyrlef
Towing Frontier on Dolly
So for some context, Towing with a 2016 Jayco Alante 31L, 5spd V10,
GVWR 18k GCWR 23k. Tires are new and PSI set to Michelin tables.
Towing a 2012 Nissan Frontier on a Demco Kar Kaddy SS with steer axle. Total length ~50'.
300 mi. trip on relatively flat terrain from DFW to Chatham, La. in T/H
Cat Scale weights showed dingy is at the dolly rated 4800lbs, GCWR is just below 23k.
Problem is the trip was a nightmare, the coach was wandering badly as if there was not enough weight on the steer axle even though the steer axle Cat Scale weight was unchanged from a previous weigh. Big Rigs wouldn't move the rear of the coach but heaved the front severly, and yes I have trac bar and safe steer and ordinarily barely notice big rigs overtaking. At speeds above 60 mph. it got really difficult to control.
I've driven trucks with excessive tongue weight which behaved like this but a loaded dolly only exerts a ~100 lb. relatively negligible weight down on the hitch.
I know there's a cause but I'm at a loss. The dinghy didn't fishtail or otherwise behave erratically.
Maybe someone else has experienced a similar issue?
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.194 PostsLatest Activity: Dec 09, 2024
