cjwink's avatar
cjwink
Truck or Tahoe
We are looking at getting another TT. Our current vehicles are a 2018 GMC Sierra SLT and a 2020 Chevy Tahoe Premier. Both have the 5.3L but VIN lookups show they have very different max towing rates. The truck is 6100lbs and the Tahoe 8600lbs. The TT we are considering is 4,600lbs dry weight. So I think both will handle the trailer, but which one would be the best option?
  • If the pickup has 6-spd trans and 3.08 gears, the performance will feel very much worse than the Tahoe with 10-spd with any available axle ratios. The pickup's longer wheelbase will likely have better stability, but I would expect a WDH with integrated sway control, both will be great.
  • cjwink wrote:
    I was surprised by the trucks 6100lb rating. The only thing I can figure is because of the 3.08 gears.
    That's exactly the reason.
    My 2015 Chevy was rated exactly the same. Performance wise, it was quite a bit better than my previous 2003 which had the 4.8L and 3.42 gears, which I can only figure is due to the 5.3L engine and 6-speed.
    You can SAFELY tow your trailer with either vehicle. It will be down to a matter of comfort. The Tahoe will probably pull it more comfortably. Try them both and see which one you like best. You may be surprised.
    There is absolutely NO reason to cower in a corner and fear towing with either of those vehicles.
  • The hoe will pull it a fair bit better than the 3.08, presumably 6 speed Sierra. The truck will handle the trailer slightly better.
    Either will be fine.
    Does it really matter if you have the option of both rigs sitting in the driveway? see which one you like best. its as easy as switching the hitch receiver to the other vehicle.
  • A low tow rating could be because of the lack of a cooling ability. On my last Suburban, my engine and transmission temps would skyrocket under a load. Give me the truck.
    This is why your tow rating is lower than expected. Some may say that longer wheelbase of truck helps with towing. I would say that you could get the travel trailer and tow it with either of your vehicles. I would choose the Tahoe as I suspect it has more equipment for comfort and ease of driving.
  • I suspect that folks sometimes have a tendency to view pickups as absolute towing and load hauling machines. But it depends on the model, 2WD/4WD, and factory equipment. Some pickups are relative lightweights when it comes to towing, and some SUVs are heavyweights (except when compared to the mega pickups).
  • I was surprised by the trucks 6100lb rating. The only thing I can figure is because of the 3.08 gears.
  • You can either crunch the numbers or add a semi-arbitrary 1,000 lbs to convert trailer dry weight to wet weight, I suspect. Both vehicles can handle that, although the SUV by a greater margin. I would suggest a better question may be if you'd prefer to tow in a pickup truck (small interior but large bed for cargo) or an SUV (large interior room, more seats). That would likely be my deciding factor here, rather than towing capacity.
  • Something sounds wrong with the 5.3 1500 trucks tow rating.
    The wifes '16 1500 chevy crew cab 5.3 6 speed 3.42 gears 4wd has a 9200 lb tow rating.
    I would think the newer 2018 1500 GMC 5.3 would be close/same to the chevy tow ratings.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.234 PostsLatest Activity: Dec 08, 2025
