I looked at the two pumps, side by side. The differences were minimal. I could find no indication of failure on the old pump. The only thing I could of is the the impeller felt tight when I tried to see if it was lose but when in the engine pumping coolant, there must be a lot more resistance and perhaps it was slipping while pushing fluid. Whatever the case, the new pump works and the truck is running great, until the ne t mechanical issue that is.
Sounds like the water pump went bad and blew the hose?
I have similar truck (99 F350, V10) with original water pump but with only 78k miles.
Good job on the on the road repair!
- Camper_Jeff___KApr 18, 2024Nomad III
I'm pretty sure the hose blew out due to the resulting high temperature pressure and boil over. My scanner in monitoring mode read 240 degrees. It's been a couple weeks now and the truck is running fine and at proper temperatures 174 to 183, never higher, never lower. Other problems have popped up and been dealt with since. This trip has been a real mechanics special so far, and something tells me the future isn't going to disappoint in the fix it department.
As Fred Sanford would say to Lamont, I feel the big one coming on. We shall see. Take care...
