CrystalB's avatar
CrystalB
Feb 02, 2024
Toilet help!
This is the current set up on the back of our toilet. The hard plastic tubbing going from the ground to the toilet started leaking. Pretty badly. We've since shut the water off completely. My question is we'd like to eventually get a dry toilet. So how would i shut off water only to the toilet? There's nothing topside that would allow me to do this. Would I need to go under the rv? If so I don't have the manual which brings me to another question. How do I find the plumbing so I know where or how to cap it off at?
I suppose until I get the dry toilet I may be able to tape the pipe? But I'll need to cap it off sometime regardless.
So..  help please
It's a 2005 weekend warrior toy hauler
  • If you just want to cap it.
    • Cut the tube just below the T
    • Use a sharp knife or razor blade to make the cut a square and flat as you can
    • Press on a sharkbite fitting.
    You can use one of these and just leave the valve turned off. Link
    Or one of these to just cap it off. Link
    Test
  • It is probably easier to take a look at it and see why it is leaking and fix it rather than trying to cap it off
  • You didn't really say where exactly the leak is so I'm assuming it's at the T junction on the pipe. First realize that T junction means there is more than one fixture served water by that pipe that comes out of the floor.My guess is that T feeds a bathroom sink so you can't just cut and cap the pipe.
    Second is unless you are going to a dry toilet this minute you should just fix the leak so you can use water in the RV.
    I would look into getting a Sharkbite fitting from Home Depot. Link  Link is for a T fitting but they also have 90's and straight fittings. They also sell lengths of the pipe in case you make a mistake and need to replace a section. Then carefully cut the leaking joint out and replace with the Sharkbite fitting. The beauty of the fitting is it's easy to use.
    Cut the plastic tube as square as you can.
    Trim the lengths of the tubes to the length that makes sure the tubes can slide into the joint and bottom out in the fitting.
    Press the Sharkbite onto the tubes. It's just a push on no need to tighten or crimp anything.
    Turn on the water and check for leaks.
    • CrystalB's avatar
      CrystalB
      I can't tell where the leak is exactly. It's too tight of a fit back there.  I think its higher up on the pipe so one of the previous answers may be correct and the rings might be replaced.
    • CrystalB's avatar
      CrystalB
      Are you referring to the tubbing that splices off to the side? That's a shower head that's attached to the toilet. It's not used as there is a separate shower.
  • Those factory clamps around the pipe are probably the source of you re leak my suggestion is remove the old clamps and install new hose clamps at those fittings you can get the clamps at any automobile parts store that just might fix your  issue
  • Am I missing something? There appears to be splice of some type wire the line goes from flexible piping to rigid piping.  Just get a plug or cap, whichever works, of the proper size, and plug or cap the flexible tubing right at that splice.
    • CrystalB's avatar
      CrystalB
      The flexible tubing is just a shower head that was spliced into the line.
    • CrystalB's avatar
      CrystalB
      There is a shower head spliced into the line as well. I thought it was weird myself but it came like that.
