FishOnOne
Dec 27, 2014Nomad
rhagfo wrote:FishOnOne wrote:rhagfo wrote:
Well, sure seems like a lot of work to drain the water/fuel separator! :S
The one on my Cummins is easily reached under the hood and is a simple lever, no tools required. :)
This is something you want to do as soon as the warning light comes on, needs to be easy and quick to do.
This RAM cummins has even a better idea... Stick the water/fuel separator near the exhaust so you can either burn your hand/arm or catch your cummins on fire when you have to drain your water. :S
Link
It appears the 1st filter is a primary, the Cummins filter water separator is still on the engine. The 1st is over the drive line, not the tail pipe although it is not too far away.
It appears you don't have a clue to what your talking about.
44,030 PostsLatest Activity: Jan 20, 2025
