Bkuhl1179 wrote:
Just purchased a 2020 Ram 1500 5.7 with the etourqe along with a 3.92 rear. Specs on the truck says it has a 1681lb payload and can tow up to 11500 lbs. Looking into purchasing a 2021 Grand Design 3250BH. Dry weight on the rig is 8450lbs and hitch weight is 850lbs. Am I crazy for trying to tow something this big? The numbers seem to be in line with what the truck is rated for.
Yes, you are crazy.
Not sure exactly what the GVWR of the trailer is but I suspect it is well north of the dry weight (10K or a bit higher)..
As it stands, with the advertised dry weight of 8450 lbs the tongue weight is too light for the trailer length and I suspect that tongue weight is heavier than what is advertised..
for absolute best towing stability you want the tongue weight to be right up at 15% and that my friend with the current dry weight would be 1281 lbs!
That's only going to leave you with 400 lbs of available cargo on your truck.. Add in a passenger or two and you are maxed out and we haven't talked about what that trailer tongue weight will be once you put stuff IN the trailer..
You have a trailer which would be far better matched to at least a 3/4 ton..
As a rule of thumb, you will run out of available cargo before you hit the supposed advertised "towing limits"..
Buyers remorse is coming soon..
