I'm gonna post this just in case someone has this issue in the future.
So this Lippert "in wall" slide is controlled by 4 motors (2 left/ 2 right) that are mounted in the wall. Those motors are controlled by a controller module (computer) that is mounted under the loveseat/sink area.
Mine was flashing an error code "break in circuit between motor and controller" (meaning a short in the wiring).
I traced all of the wiring and all of it was undamaged so I bypassed the module to see if it would work. You can do this by pressing/releasing a button 6 times and press the 7th time and hold it until lights start flashing.
Next, I pressed the regular slide switch on the wall and the slide worked perfectly. The computer reset itself and is not flashing any codes. I moved the slide in and out several times and all is fine.
Outer Banks, NC... here we come!
2005 Silverado 2500HD Crewcab 6.0, 4.10 gears (300hp/360torque/10,800 towing capacity
TV- 2013 Forest River Salem Cruise Lite 281QBLX (5400 dry weight)
Ava-Wife
James-Toddler
