โDec-15-2014 01:09 PM
โDec-16-2014 05:30 AM
โDec-15-2014 05:36 PM
โDec-15-2014 05:13 PM
โDec-15-2014 04:52 PM
Porsche or Country Coach!
โDec-15-2014 03:44 PM
โDec-15-2014 02:31 PM
SteveAE wrote:
Grandpa,
IF you want to run your microwave from your batteries and recharge them via solar, then you will likely need:
- Four batteries
- A 1200 Watt (or bigger) inverter
- Short and large (diameter) cables between the inverter and the batteries
- And a 200 to 300 watt (minimum) solar system (and plan to use power conservatively at that)
This type of system works well ..... for me. But you best verify that this is really what you want before jumping in as it isn't cheap to do.
Steve
โDec-15-2014 02:11 PM
โDec-15-2014 02:06 PM
grandpa123 wrote:I recommend a 1500 watt Go Power sine wave inverter.
Beemer! My micro wave is only a tiny 700 watt. Wife usually warms things up in it at lunch time such as a bowl of soup or such once or twice a day at most.
โDec-15-2014 01:56 PM
โDec-15-2014 01:43 PM
โDec-15-2014 01:40 PM
โDec-15-2014 01:31 PM
