โMar-12-2016 05:59 PM
โMar-14-2016 09:44 PM
Jim2007 wrote:
Hi All.. Thanks for all the help on my question. Thomasmnile; Yes, the band have been adjusted if needed at each flush. I do not know which slush box I have. Jim2007
โMar-14-2016 08:53 PM
DirtyOil wrote:.Jim2007 wrote:
Hi All: This truck has about 110k. I have done alot of work on the engine and no major work on the auto. transmission. I would like to keep using it as our tow vehicle. I have changed the transmission fluid every 30k as recommended by Dodge. It is my understanding the color of the fluid is about the only indicator of problems in the transmission. Is there other indicators? The shifting between gears is smooth. Thanks for comments. Jim2007
Other then fluid colour, look into the pan see how much debris has collected on the bottom of the pan and around the magnet. Changing fluid and filter along with adjusting the bands(over doing the adjust will kill the tranny fast)is all you need to do. As for others suggestions of adding/removing this or that, not required, unless your going to run a programmer to increase HP/TQ.
โMar-14-2016 07:07 PM
โMar-14-2016 05:31 PM
โMar-14-2016 10:52 AM
โMar-14-2016 10:19 AM
โMar-14-2016 09:34 AM
โMar-14-2016 07:29 AM
StewC130 wrote:I for one am not a fan of Sun coast. That was the T/C they used on my rebuild. It went out 25 miles west of Circle,MT. cutting the front pump up and seal leaking fluid all over every where. At this point I am 1400 miles from the shop that did rebuild so they sent parts out to Circle and I am on my way 4 days later. The local shop pulled my trans for a look see when I got home and also paid all of my extra expenses we incured like rental car, hotel etc. It does not have a Sun Coast in it now.
Same truck as yours. At about 160K a ring broke in the overdrive unit and cut a groove in the overdrive gear. Got it replaced but could never get all the fine metal out. It finally started collecting on the solenoids so I had the tranny rebuilt local. Lucky for me we have a company called Suncoast Transmissions here and they build a great product. Best thing I ever did. I picked up a couple miles per gallon because the thing was slipping so bad before the rebuild. Installed a triple disc converter, new valve body, billet input/output shafts, and other stuff. Raised the pressure so it really locks into gear now with minimum to no slipping. Dodge built some slip into the tranny because of complaints that it shifted too hard which eventually leads to wear of the parts.
โMar-14-2016 02:49 AM
โMar-13-2016 06:02 PM
โMar-13-2016 08:47 AM
โMar-13-2016 06:29 AM
โMar-12-2016 10:45 PM
โMar-12-2016 06:07 PM
