maxwell11
Jan 26, 2016Explorer
2004 Ford pickup 5.4 liter motor tick noise
the motor on my son's 2004 Ford pickup, 5.4 liter motor has started making a ticking noise after it's warmed up,
94,000 miles, truck is in excellent condition other than this minor ticking noise.
you can hear the noise at idle, but not when driving down the road.
he uses Ford oil filters and Ford oil 5W20.
most of you guys that ever owned a truck this model have probably traded them off for newer trucks by now.
but, do you ever remember having a motor tick with your 5.4 liter Ford motor.
if so, what is the cure, is it a valve, injector, it does not miss, so I would not think it was a plug loose.
I really do not know what to tell him to do, as he likes to have his vehicles in top condition.
he only drives the truck approximately 8,000 per year. has the oil changed at 6 months or 4,000 mile intervals.
reason I ask here, he has ask the dealership, local repair shop and one or two others, who should know about this model motor, has gotten a different answer from each;
bad plugs, loose or worn timing chain, flywheel loose, coil packs bad,
etc:
Thanks for any suggestions,
I suggested changing the oil, use Ford filter and 5w20 oil, but replace one qt of oil, takes 7 qts (I think) with one quart of Lucas oil stabilizer,
might be worth a try, before letting some one tear into this motor,
again, any suggestions are appreciated!
etc:
