mbrake's avatar
mbrake
2006 Alpenlite Saratoga 935 Air Conditioning Pre-wiring
The manual states that pre-wiring exists for an optional A/C unit and the wiring is 12/2 wiring to a 50/70 junction box with blank plate. Does anyone know where that junction box is located?
  • I'd imagine in the ceiling, at or near an existing vent or fan that could be removed to install an AC.
    Do you see the wires/breaker pre-installed in the breaker panel?
  • I do not have an Alpenlite but normally if it is prewired it is in the rear or center 14 x 14 roof vent and the outlet should be right next to it. Here are a couple of pics of my Lance 1181.
    The wiring is also seen when I pull the trim out from the inside.
    Hopes this helps and I have many more pics. You are in the right place. It may take some time to get the conversation started.
    Joe
