- hbhconstructionExplorerYes i have lubed as part of getting ready for this season. Doesn't seam to bind at all when going out. I wanted to find where it is located and try changing out to see if there may be some corrosion. I will also try to test the amp draw when moving slide once located. Thank you for the suggestions.
- AirForceAnglerExplorerMore important than locating the breaker is trying to figure out why the breaker is resetting. For some reason, it is tripping and this shouldn't happen if the system is working properly. Have you lubed the slide components lately? Is it binding somewhere?
About Travel Trailer Group
44,025 PostsLatest Activity: Feb 06, 2025
