- JimPHExplorerI had a 2012 GMC SRW 3500 that I carried a 2007 Lance 1055 11 ft camper. Just put a 3/4 sheet OSB and two rubber mats. Cleared the back of the bed where it curves at the bottom with no problem while giving total support to the bottom of the camper. Did this for four yrs until I purchased a new truck
- Kayteg1Explorer IIDealer had 2x8 osb planks that he gave to me and I put 3/4" plywood on the top. Add about 1/2" for factory mat.
My aluminium bed is a bit longer than 8' so I put plank up front and additional 1/2" strip under at the rear, so camper/platform in the rear have good support and don't rock on bed ribs. - MLDExplorerWhat did you build your platform out of?
- Kayteg1Explorer IIUnless you find member with exact set up - you will have to measure it.
I have Lance 1161 on my new F350 and had to build 3" platform to clear side railings.
About Travel Trailer Group
44,025 PostsLatest Activity: Feb 06, 2025
