shane0991
Jan 24, 2016Explorer
2006 SunnyBrook Titan 30fks blowout damaged wiring
Hello all,
I had a blowout on my SunnyBrook. Damaged the fender not a big deal but it did managed to rip a bunch of wires apart underneath. All the wires that were damaged are 10 or 12 gauge there are one black and one white coming from the front. Two black and Two white running towards the back. A single white and black that runs towards the slide motor area. Every thing in the rv is working with the exception of the slide. I hand cranked it out. Wall outlets on the slide work but the 12 volts lights do not. Does anyone have a wiring diagram? I have checked all the fuses and breakers are good. All I have done so far for safety is put wire nuts on the cut ends to make sure they do not short anything. Any help will be greatly appreciated.
Thanks
Thanks
