- rowekmrExplorerThanks good info here. I just got a 2011 Ram 2500 and wasn't sure either.
- Ron3rdExplorer III
Grit dog wrote:
Correct
Good info, thanks. - Grit_dogNavigator IIICorrect
- Ron3rdExplorer III...so if I understand this correctly, both the 2011 CTD and the 2017 can use the same filter under the hood, the newer filter is just updated and better?
- Grit_dogNavigator IIICommon rail filters
03-07 Single filter 5 mic is the best you can get, many are 10 mic and they need addl filtration.
07.5-09 single filter. Idk the micron rating but believe they need addl filtration too.
10-12 single filter, use new truck filters they're 3 micron. Same as secondary filter on 13-up models
13-present. Primary filter is new, secondary filter is same size/design as 10-12 filters, but better filtration. - Ron3rdExplorer III
jus2shy wrote:
not to add to the confusion, but the later model engine fuel filter is much better than the original fuel filter used in the before the 2013 trucks. He can use the engine filter just fine (in fact it is a superceding part I believe), only return the rear fuel filter.
Ok, thanks - jus2shyExplorernot to add to the confusion, but the later model engine fuel filter is much better than the original fuel filter used in the before the 2013 trucks. He can use the engine filter just fine (in fact it is a superceding part I believe), only return the rear fuel filter.
southernsky wrote:
The answer to your question is "No". My 2011 has one filter under the hood. I get mine off line from Ebay
That's what I thought. My 2016 has the two filters but I thought the 2011 had one. My son in law bought the filters at the dealer for his 2011 and said they sold him two filters so he's probably was give thge later model filters. - southernskyExplorerThe answer to your question is "No". My 2011 has one filter under the hood. I get mine off line from Ebay
- azrvingExplorerMy son has an 2011 with one under the hood. Pre def requires 67000 or about that many miles egr cooler/ egr valve cleaning. I have heard $1200 dollar service but not sure. I did my sons for him.
About Travel Trailer Group
44,056 PostsLatest Activity: Nov 19, 2013
