2013+ ram 3500 receiver hitch height
2012Oudoorsman
I just ordered a 2016 Ram 3500 and I know it will sit much higher than my 2012 Ram 1500 and im curious if I need to buy a new hitch shank. Could you please let me know how high it is from the ground to the bottom of the receiver. Im not sure how long it will be till I get it so if I need to get one I would like to get one prior to camping season next year. Its a 1200lb equalizer with standard shank. I plan on using it with the new truck.
Shouldnt feel that 7500lb camper with the 6.7 cummins with the aisin transmission. Ordered the truck so its all ready when we uprade to a fifth wheel.
Thanks!
12 REPLIES 12
spoon059
2012Oudoorsman wrote:
Any chance it has any part # on it. I had a hard time finding any husky shanks online. Camping world is the only close dealer and this one is horrible so I refuse to purchase from them. I found the equalizer one for $155 on etrailer.
Unfortunately I don't know what the part number was. It was on a sticker that immediately came off. I paid $80 for my shank in store. It was cheaper than buying on-line, plus I needed it NOW... I had bought the new truck a week before we went camping and we have a STEEP driveway. Without the proper drop shank I would have been stuck trying to leave the driveway!
2015 Ram CTD
2015 Jayco 29QBS
Grit_dog
Navigator
Navigator
That 3500 won't sag as much as the 1500 once loaded either unless you had the WD bars cranked way up on the 1500.
I'd guess the new truck won't drop but an inch or 2 total with all the tongue weight so figure that into the drop as well. Unless you're getting a height adjustable hitch maybe wait til you can hook up the new truck for a real measurement.
IdaD
agesilaus wrote:
Why don't you go by the dealer's lot with a tape measure. That's what I did when I was worried about rail height. 4WD vehicles may be different BTW.
Tried that when i ordered but neither dealer i visited had a 3500 on the lot. They were both smaller dealers who dont do a lot of heavy duty sales. Ive read that the 2500 sit higher so I didnt want to bother with those or a drw. It doesnt have to be spot on, but a couple numbers when averaged would probably get me close enough to tell me if I should be good or not.
Ive already found the 2.5" shank with a longer drop that will work with my hitch on etrailer but wasnt going to purchase unless I either found I needed the extra drop or two, the hitch felt too sloppy with the adapter.
My 2500 sits exactly an inch higher than the 3500 picture posted above. Just figured I'd answer that open question.
2015 Cummins Ram 4wd CC/SB
2012Oudoorsman
spoon059 wrote:
Just a heads up, the Equalizer brand shank is super expensive. I bought a Husky brand from my local RV parts dealer for about 75% of the cheapest price I could find on the Equalizer. The weight ratings for the shank are the same, the width of the shank is the same and the hole diameter and spacing is the same.
spoon059
2015 Ram CTD
2015 Jayco 29QBS
2012Oudoorsman
Ram4Sam wrote:
Here you go......
Sam
Awesome thanks!
The bottom of mine is 19" and yours is 21 3/4" once the adapter is in. I can drop another hole which puts me another 1 1/4" closer but still off 1 1/2". Kmowing the trailer handled bad when slightly nose high it looks like I should be buying a larger drop shank.
Ram4Sam
Here you go......
Sam
2016 Dodge cummins 3500 SRW LB CC 4X4 Aisin, Nav, white w/brown
No keys, B&W TOB & Companion
Gone....served me well...1991 Dodge Cummins...2001.5 Dodge Cummins
2008 Thor Jazz 2870UK 5er
Driving a Dodge Cummins since 1991...
spoon059
You will need a drop shank for sure. I had to go buy a 9" drop shank for mine.
2015 Ram CTD
2015 Jayco 29QBS
2012Oudoorsman
Me_Again
The new RAM will come with a 2.5" Receiver. The adapter to 2" that comes with truck is a sloppy fit. I would get a new 2.5 hitch. Chris
JoeGood988
X2...All trucks are different...tape measure is a sure bet
2003 3330 Jayco Legacy
agesilaus
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
400W Solar with Victron controller
Superbumper
