jstika's avatar
jstika
2014 R Vision Trail Trek 322bhd
We just bought a used R Vision Trail Lite Trek from a dealer. The bunk key for the electric bunk was supposedly given to us, however, cannot locate it. Does anyone have this type of key or know where to get one so that we can use the bunk bed. We have contacted manufacturer, RV specialty key dealer and have had no luck. Please help!!!
  • Glad you found a solution. As I mentioned you could put in a non keyed switch so a lost key would never be a problem. Enjoy the new camper,just need warm weather.
  • We were able to access the key switch by pass and disconnect the wires....connected the wires together and got it to work....at least it is a temporary fix....thank you for the help....
  • Sorry I have not replied back earlier. I think you could remove the key switch and replace it with some sort of non-key switch. Another option is to bypass the switch altogether if you can get to the wires. Hope you can find some sort of resolution to this problem.
  • I do believe that is a keyed switch, however, the key hole is in a separate location to the retract/extend switch. the key must be turned to operate the bed...safety reasons since it is in a buck room...I have seen a picture of the key and it is not a normal key buy more of a lift key....
  • Possible for a locksmith to remove and replace??
  • What is the key for? To secure the bunk or a keyed switch?
