- Slate_CMExplorer II
time_traveler wrote:
Any WD hitches you can recommend
Also are you happy with rear kitchen set up
I'm not sure on the WD, I just bought the one the dealer had in stock. I don't remember the brand but it seems to be fine. Just make sure it is set up correctly.
The dealer just hooked it on the first link in the chain and sent me on my way. The 100 mile ride home felt like boat on choppy water. After a local repair guy adjusted it properly the ride was much better.
This is my first TT, but I like the rear kitchen. It provides more counter space than other layouts in a similar size. - time_traveler1ExplorerAlso are you happy with rear kitchen set up
- time_traveler1ExplorerThanks for response
Yes I have tow package and 5.7 motor
Any WD hitches you can recommend - Slate_CMExplorer III think you will be fine with that combination, assuming you have the 5.7 motor and tow package.
I have a 2008 Tundra and my TT is 2015 Springdale 241RKSWE. It has almost exactly the same weight specs. The interior looks pretty much identical.
So far I've been pleased with both truck and trailer.
About Travel Trailer Group
44,027 PostsLatest Activity: Mar 06, 2025
