2015 salem cruise lite peeling sofa question
mobilefleet
badly peeled sofa in bunkroom, 60" wide. There's a tag on top and bottom parts of sofa, one says e19 and the other says e28. I don't see any other identifying info, but these are zippered and appear to be removable/replaceable as they fit over the metal frame and foam insides. Anyone ever replaced these or know anything about the tag numbers? seems a cover designed for jack knifes would be much cheaper than a whole new sofa
4 REPLIES 4
ScottG
Deleted
paul_jensen
Good luck!:)
wildtoad
Most covers for jackknife sofas are just junk. Check with a good auto/marine upholstery shop. Upgrade the material.
Tom Wilds
Blythewood, SC
2016 Newmar Baystar Sport 3004
2015 Jeep Wrangler 2dr HT
stickdog
Don't know the specifics of your sofa but they all can be reupholstered and as they are zippered should be no problem getting them replaced.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
