nineback wrote:
If you are over on your rear axle then I think that would be reason for concern if you were ever checked. I understand the "checkers" look at tire ratings and axle ratings.
Tom
Cummins12V98 wrote:
1jeep wrote:
the way things are going in Ma I wont be sureprised when they require people to have their RV's inspected along with the truck. Once they start doing that do you think it is so far away that they start weighing them? I almost got failed this year because my truck didn't have wheel chocks.
As long as you have the tonnage to cover the weight on your 4 or 6 tires you will be fine.
I need 16K to be "legal" with my actual scale weight. I am under FAWR slightly over RAWR and under my GCWR.
The scale folks due.check tire and axle capacities. 500 lbs per inch width of tire, up to 20k per ax with enough tire width, and 34k if the axles are closer than around 10' iirc.
They do not look at tire sidewalls, as they can not see the sidewall spec from inside weigh scale shacks. They enforce the road bed design max load spec, NOT the engineer design spec from the manufacture.
Cummins 12v is legal, would not get an overweight ticket as loaded that day.at the cat scale.
I've been pulled over at 150 percent of manufacture give, I have yet to get an overweight ticket as I was under paid for license weight.
Marty
