Nov-21-2020 12:25 PM
Busdriver
2019 2500 Chevy Duramax , - 2017 Grand Design 303 RLSNov-23-2020 06:57 AM
deltabravo wrote:ktmrfs wrote:
duramax will also go to high idle in neutral during a cold start on cold days to help warmup. RPM will go to somewhere between 800-1000 IIRC, grid heater stays on, turbo goes to max backpressure and throttle valve is activated. All this to help warm up.
Doesn't the high idle only engage if you have the setting turn on in the DIC?
On my 2009, elevated idle has to be enabled in the DIC before it engages at the OAT temp that causes it to engage
Nov-23-2020 06:08 AM
deltabravo wrote:S Davis wrote:
I keep an eye on my soot level and if I am getting up there and driving more than 30 minutes I will force a regen.
How does a person "force" the truck to regen?
What year is your truck?
Nov-23-2020 05:14 AM
Nov-23-2020 05:11 AM
Nov-22-2020 06:36 PM
RobWNY wrote:
This thread has been interesting and a learning experience for me. My 2020 Duramax and first diesel vehicle was idling high yesterday. I thought it was too warm outside for it to be idling higher than normal. Now I understand why! Thanks for teaching this old guy something 🙂
Nov-22-2020 04:12 PM
Nov-22-2020 02:20 PM
NRALIFR wrote:4x4ord wrote:
When Ford starts a regen that gets interrupted the regen is canceled till the filter reaches 100% full before initiating another attempt.............
That’s the way mine works, and there have been a few trips that just weren’t allowing a full regen to occur. It’s maddening to see that happen several times in a row. I wish when the DPF gets above about 80% soot load, it would allow you to start a manual regen. There have been too many times that if the ECM would just start the regen at the beginning of a short trip, it would have plenty of time to finish by the time I reach the destination. Instead, it seems to wait until just a few minutes before I get to where I’m going. Then it only has time to burn off about 10% of the soot.
Nov-22-2020 10:54 AM
Nov-22-2020 09:43 AM
Nov-22-2020 09:25 AM
Nov-22-2020 05:39 AM
Nov-22-2020 04:58 AM
4x4ord wrote:
My bet is that the programming change of initiating more regens is because our trucks seldom enter into a situation where they can do one long complete regen before we either reach our destination or enter into traffic conditions that interrupt the process.
Nov-22-2020 03:27 AM
Nov-22-2020 03:08 AM
