devildog1971's avatar
devildog1971
2019 Northern Lite 10-2 CD
I turned on the furnace and now I have a question, should the thermostat have a light in the thermostat so the numbers can be seen without using a flashlight, even with the overhead lights on it is hard to see the thermostat heat numbers.
  • burningman wrote:
    This is a non-issue. You can put any thermostat you want on there.
    It’s super easy and cheap.
    Not sure how this is a question actually.
  • K Mac wrote:
    My little red thing broke years ago, lol.
    There's pills that fix that now...
  • This is a non-issue. You can put any thermostat you want on there.
  • You're correct that there is no light in the thermostat. My 2018 10-2 is the same way. Wish NL would have used a better thermostat with a light.
  • I have a light. It’s nice. Turns off in about 10 seconds.
