Old-Biscuit
Apr 12, 2020Explorer III
Battery should not overcharge provided your converter is functioning properly.
2020 vintage trailer should have a decent 'smart' converter/charger
Smell from electrical panel needs investigated
Check that ALL terminal screws inside the panel are TIGHT
From the CBs, at the ground bar, at the Neutral bar, at the DC Cable lugs on fuse panel
Look for ANY burnt signs....melted insulation
Electrical smell means loose connections or melted insulation which can end up arcing/burning---FIRE
44,029 PostsLatest Activity: Jan 13, 2025
