2020 KZ sportsmen se TK tire blowout (advice needed)
Rbraswell
I had a blowout heading from central GA to Panama City Beach, FL. The blowout happened in AL on the way through.
The blowout broke my fender skirt and also tore into the Darco fabric and snatched some insulation out as well.
I patched it with gorilla tape to get me home.
I put in some new insulation and also ordered and installed a โ€œunderbelly repair kitโ€ that I found on Amazon (***Link Removed***)
Iโ€™m wondering if this fix will suffice to future wear/tear and weather?
What should I do next? Run with it or?
Iโ€™m unable to attach my pictures on here.
5 REPLIES 5
WayneAt63044
I, too, shredded a tire which tore up the inside of the "wheel well". I replaced the material with Coroplast, the black corrugated plastic board that lasted for years without deterioration. It handled road spray and rocks from the tire flawlessly. I screwed it into the bottom of the flooring and sealed the edges to make it waterproof.
2012 Forest River V-Cross Vibe 826VFK
pulled by 2009 Ram 1500 Quad Cab Hemi
Rbraswell
This is after I put in the insulation in and before I put on the patch kit I ordered on Amazon
This is the patch and flex mend tape kit on put on. I sealed it to the frame, because there was only a sliver of Darco fabric left closest to the frame. Iโ€™m worried water may seep into the small crevices where it doesnโ€™t get a great seal at the end of the tape on the frame.
BarneyS
Nope
2004 Sunnybrook Titan 30FKS TT
Hensley "Arrow" 1400# hitch (Sold)
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
BB_TX
First time poster is not allowed to post web links. Does that apply to pictures also?
BarneyS
If you will follow these directions exactly, it is very easy to post pictures on our forums. One of our moderators, 1492, developed this photo posting app to post your pictures. It works for other internet sites also. There is no need to have a separate hosting site for your pictures in order to use it.
It is very simple to use. Follow these directions exactly. Do NOT make any changes to the results when you get them.
1. Upload your picture from your computer to the app.
2. Copy the resulting URL.
3. Paste that URL into your post
without ANY changes. No additions or deletions.
Your picture will then appear in your post and be properly sized for use on our forums.:)
Not towing now.
