colliehauler
Sep 29, 2020Explorer III
2021 Ford F-150 hybrid
Seen it can tow up to 14,000# and the electric motor can act as a generator producing between 2.4-7.2 kilowatts depending on configuration. Sounds like a good match for RV owners.
Dadoffourgirls wrote:The article said (14,000# tow rating a 800# increase over the 2020 model. This model is also capable of hauling a 3325 payload).
The hybrid will be able to tow up to 12,700 pounds and haul up to 2,120 pounds, Ford says.
jdc1 wrote:
Hopefully it's a plug-in version, having the ability to travel 25 or more miles on electric only.
Nope. Not nearly battery to even consider that.
Groover wrote:
"This model is also capable of hauling a 3325 payload"
I will be much more impressed if the payload package is more obtainable and can be combined with the higher towing ratings. It has been almost impossible to get for the last 6 years and required seemingly unrelated compromises if you did special order it.
