Jun-19-2015 08:10 AM
May-27-2016 06:20 AM
May-27-2016 04:57 AM
B-n-B wrote:
Holy dead thread Batman! :S
May-26-2016 10:45 PM
May-26-2016 09:15 PM
May-26-2016 06:59 PM
Jun-24-2015 02:02 PM
Jun-24-2015 01:21 PM
JIMNLIN wrote:RoyBell wrote:
Curious as how Ford can increase payload so much over other half tons. Is it the Aluminum body, beefier springs? What are the axle ratings?
Because they use a higher 7850 GVWR than other 1/2 tons.
One poster mentioned look at the numbers.
Ok lets do some math.......real numbers.
Any F150 out here cannot carry 2650 lb payload in the bed of the truck. Even the F150 HD with those bigger 4800 RAWR will be over loaded when placing all 2650 lbs in the bed such as a truck camper or 5th wheel or load of RR ties from the farm and ranch store.
The F150 super crew 4x4 truck may weigh 2500 lbs on the rear axle (probably more).
Now add 2650 lbs in the bed.
According to the math 2500 plus 2650 = 5150 lbs for a overloaded 4800 rear axle/wheels and rear suspension.
The most a F150 HD with a 4800 RAWR can carry in the bed is around 2300-2400 lbs before the rear axle is over loaded.
GVWR payloads will be placed over the trucks front and rear axles such as a plumbers over head rack that sits in the bed and the front of the trucks frame.
Years back a 1/2 ton might of had 6200-6600 GVWR and 3800-3900 RAWR so a GVWR payload didn't over load the trucks RAWR.
As was mentione look at the numbers. Then do some math.
Jun-24-2015 12:55 PM
Jun-24-2015 11:37 AM
Boondoc wrote:
You will be getting 8-11 mpg,.
Jun-24-2015 11:32 AM
Jun-24-2015 10:33 AM
hawkeye-08 wrote:
I think the big mistake is folks look at tow rating (I know I did at first), not realizing that the payload or hitch specs are going to come into play before tow rating in most cases with travel trailer...
Jun-24-2015 10:09 AM
hawkeye-08 wrote:
Folks should stop thinking of needing a 1/2 ton or 3/4 ton or 1 ton, but rather work the numbers for their setup (or proposed setup). There are many capable trucks out there, get the one that meets your needs.
Please don't assume from post above that all Ford F150s have a 2650lb payload, but there are some. The door sticker is your friend.. Some 3/4ton pickups have dismal payload ratings.
We have a 3/4ton that is my occasional driver (I work from home), but otherwise is dedicated to towing.
Jun-24-2015 09:51 AM
Jun-24-2015 06:25 AM
