- BackOfThePackExplorerhttps://duckduckgo.com/?q=airstream+triple&t=iphone&iax=images&ia=images&iai=https%3A%2F%2Fi.pinimg.com%2Foriginals%2Fe8%2F09%2F7b%2Fe8097b928fb91d3be342516867ed1c15.jpg
Airstream and AVION both made 34’ triple axle TT from circa 1978 to 2006.
I’ve a 35’ Silver Streak, but it’s tandem axle.
These trailers were approx 9-10k gross. - TCBearExplorerI checked the online trailer dimensions, then carefully crunched the numbers and concluded you could fit precisely 17 kangaroos inside those Aussie rigs, along with 8 koalas and 12 cases of Foster's Lager. And then it's Party Time!!
- RobertRyanExplorer
4x4van wrote:
30' are not uncommon here in the US. Both of those look considerably larger than 30'
One was 32ft - RobertRyanExplorer
Grit dog wrote:
Roflmao. RR you crack me up!
I like that first trailers interior though.
You would be amazed how many are like that as regards interiors. Very very competitive market here. Grit Dog you could learn a lot how others do it outside the US and Canada as you do not have much of an idea - spoon059Explorer IIMine is 32'
- Grit_dogNavigatorRoflmao. RR you crack me up!
I like that first trailers interior though. - 4x4vanExplorer III30' are not uncommon here in the US. Both of those look considerably larger than 30'
- RobertRyanExplorerThis is a 26ft Off Roader it needs this to tow it
Or something like this - RobertRyanExplorer
prichardson wrote:
Those look bigger than 30 feet. The first one appears to have an aluminum frame, which is interesting.
Yes one is 32ft - RobertRyanExplorer
BB_TX wrote:
30' and longer is not uncommon here. But not with 3 axles. Those look a lot heavier than what we see here.
Yes they are a lot heavier maybe a HD Pickup Dually or more the case here a Japanese Light or light medium duty truck
About Travel Trailer Group
44,029 PostsLatest Activity: Jan 21, 2025
