Campfire Time wrote:
Mvander wrote:
My parents just picked up a new f150 with the base 3.7 v6 and it should work well towing their 14rb starcraft. Some people dont need the extra power and there is a savings at the pumps even if its only a few mpg. Plus the cost of the upgrade in the first place. You can save thousands over the ownership period buying only what you need.
But that's the point. The MPG savings are insignificant. And the cost of the V8 isn't all that much more. There won't be any difference in insurance costs or maintenance. I'm not convinced that you'll save thousands over the ownership period.
Uh, except that isn't true.
In some cases, insurance can be cheaper, especially for young drivers.
Maintaince will be less expensive when it's time to replace spark plugs, and it's not unusual for V6's to require less oil and use smaller/less expensive oil filters.
Initial buy-in for a V6 is less than the V8, and gaining 1-2MPG over the ownership of the vehicle can be significant, depending on how much one drives.
the V8 engine is one of the most expensive single options on a truck, behind only 4x4 or cab options, etc. If you never tow, and don't drive like I do, then a V6 is at least worth considering.
Now for me, I always check the box for the biggest and/or most powerful engine on the option sheet, but not everyone is like me.
