Aug-25-2020 05:44 AM
Aug-27-2020 09:45 AM
Me Again wrote:Cummins12V98 wrote:
YES, sometimes ya have to be smarter than the computer. Kinda like dropping a bear before the grade starts.
What caliber do you us for bears? Does your AR-15 take one down? How many rounds does it take?
Aug-26-2020 05:54 PM
Aug-26-2020 04:07 PM
Aug-26-2020 02:11 PM
IdaD wrote:Cummins12V98 wrote:IdaD wrote:
Auto coupled with tow/haul when towing is awesome going down grades because it holds whatever speed you set with a brake tap or taking your foot off the accelerator, adjusting the amount of compression and/or downshifting as necessary. Even on the big grades we have out west the only time I have to use my brakes is when I need to slow down for a corner, traffic, etc.
I do use my EB when I'm not towing if I remember to turn it on, which is not all the time.
Try it with 26k behind you going down a 6% great. It will NOT hold.
I run TH and FULL EB and use cruise and lock out the same gear I would have came up the grade. I set around 50 for holding 55 in 3rd on 6% grades.
I can go down several miles of 14% locked in 2nd with cruise set to 30 or so and be running 35mph.
I've never pulled that much weight with this truck so I'm just passing along my experience with a more typical size camper. I've pulled more than that with old farm trucks with no exhaust brake at all but that's a different topic. Frankly I don't ever see myself with a camper anywhere near as large as yours as I don't have any desire to ever live in one long-term. Different strokes I guess.
Aug-26-2020 01:40 PM
Aug-26-2020 01:30 PM
Aug-26-2020 09:28 AM
Aug-26-2020 07:48 AM
Aug-25-2020 07:40 PM
rhagfo wrote:Walaby wrote:
Give this thread enough time and you will see mixed thoughts here too. I suspect what you read here will largely mirror what you've read elsewhere.
I don't use it driving around city, but use it towing or not on the freeway.
Mike
Well the Cummins exhaust brake uses a sliding ring, not the variable blades in the turbo. My thought is use it or loose it.
Aug-25-2020 07:24 PM
Mike
Aug-25-2020 06:51 PM
Aug-25-2020 06:48 PM
Cummins12V98 wrote:
Start truck, hit TH and EB EVERY time towing or not!!!
I never use the Auto mode.
Aug-25-2020 03:57 PM
Aug-25-2020 03:50 PM
