Terry_25's avatar
Terry_25
'96 Jayco Roof Repair
Need to replace a 3'x5' piece of plywood to repair a seriously leaking skylight. Bought the EPDM material from Best Products and you order by the foot in 10' width so I ordered a 4'x10' piece. After I cover the new wood, I thought I'd just strip the adjoining rubber and run the new the rest of the way across the roof.
Will the new adhesive stick to the old or am I going to have to sand it off or chemically remove it? Thanks for any help.
  • I agree with using Eternabond tape. Read the instructions and take your time. The repair will outlast the trailer.
  • mobilefleet wrote:
    I would use eternabond on the 2 seams and you will be all good
    This is the correct answer!
