spyder152's avatar
spyder152
A/C gasket
Just wondering if there is something better than the foam gasket for the roof connection on the a/c. It finally rained in California and now I have a small leak at that connection. It just seems that if will still leak with the stock foam gasket. There has to be something better. Thanks
  • Triker33 wrote:
    Maybe yours need tighten down some.
    They are 4 bolts that do that.
    x2
    Mine loosened twice and leaked. The second time I tightened them, I added loc-tite to the screws.
    Foam is the only type of gasket I've seen too.
  • I am missing one bolt, I'll get it replaced and see if that's the problem. Thanks for the reply.
  • Mine leaked just a little. I tightened all of the bolts another turn and no leak since.
  • Maybe yours need tighten down some.
    Just don't tighten it too much or a leak can start that way also.
    All AC gaskets or foam type. And they are thousands that don't leak.
