wyattm's avatar
wyattm
AC Blower Replacement
I have a Duotherm brisk air ac unit and I need to replace the motor and blower wheel. How do I get the blower out of the blower housing? Is there a way to remove the housing?
  • Its more than just remove plastic cover. When you remove the out side cover the blower sets inside a metal and Styrofoam box i need to know how to get this box apart.
  • mobilefleet wrote:
    take off the plastic cover on the roof and then unbolt it from the bracket that holds it on
    This^^^^
    And you may have to remove condenser fan blade metal shroud to get motor/fan assembly out.
  • take off the plastic cover on the roof and then unbolt it from the bracket that holds it on
