hbillsmith
Dec 18, 2013Explorer
Adapt TT Propane Port to eliminate Grill disposable bottles
Finally found a connection hose that will go from the built-in propane port on the trailer to a grill that uses portable propane bottles. The Kodiak 242RESL came with a bumper mount grill that I don't care for. I was looking to change to either a Coleman Roadtrip, Weber Q or Charbroil X-200.
All of these use the 1 pound disposable propane bottles. I've seen Youtubes on how to remove the regulator and convert them to a direct connect, but I don't want to do that. I want to leave the ability to use portable bottles. I am aware that the built-in trailer system has it's own regulator and that if I simple connect to the grills regulator, the effect will be that the gas is double regulated. It won't matter! The primary complaint on most of these little grills is they get too hot. Double regulating will only reduce that problem. I've seen many threads where users say 'it just doesn't matter' and the two regulator issue is a non-issue.
The solution is sold by Calore Equipment's Magento line as RV Quick Connect Hose with 1"-20 Disposable Bottle Male Connection. Click the name, it's a link to the product at the Calore site.
Link to RV Quick Connect with Disposable Bottle Male connector
For $27 it's the solution I was looking for. The hose standard length is 4 feet. You can order it longer by adding ($3-6'; $8-10'; $12-12').
