roadrat2
Mar 18, 2018Explorer
Add a heat strip to Dometic Brisk air
We're thinking of adding a heat strip for those chilly nights that aren't cold enough to need the furnace. I know these will not 'Heat' the camper. We just want to take the chill out.
I know we will need a new thermostat.
So, is installing the heat strip an easy job...hopefully 'plug and play'? I'm guessing it goes downstream of the fan, just inside the air outlet. Also, will I need to run an extra low voltage wire to the thermostat?
Thoughts and experience from anyone who has done this will be appreciated.
