Advice needed -- will I regret a shortbed w/ 43' trailer?
loudounrv
I'm about to make a decision on a TV - Ram 3500 dually. I hope to have 14000 lb, 43 ft fifth wheel later this summer. I have 3 kids so I'm leaning towards the Mega Cab option for the added comfort for them, but of course this means I'll have a 6'4" box.
Am I going to regret having a shortbed every time I'm trying to back that trailer into a tight space, or will one of the slide hitches solve my problem? Can you recommend some good hitches to consider?
Thanks, Tom
25 REPLIES 25
M_GO_BLUE1
I doubt you even have enough truck for a 43' footer...
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
Devocamper
doesnt the mega cab have lower tow ratings do to the extra weight of the larger cab?
08 NU-WA Hitchhiker Discover America 339 RSB Sold
18 Host Mammoth
07 Chevy 3500HD LT1 EXT Cab LB DRW D/A Sold
18 Ram 3500 SLT Crew Cab DRW 4x2 6.4 4.10's
army_guy1
Look at the crew cab - there is only a few inches difference in the rear. I, myself, would have nothing but a long bed.
Rick & Jana
Full timing since Oct 2005 - retired US Army Dec 2009
2018 Arctic Fox 27-5L
2014 RAM 3500 Big Horn
ib516
Lantley wrote:
As others have mentioned be sure you have enough payload and beware many short beds have small 26 gallon fuel tanks
My Megacab shortbed has a 35 gal tank.
I think whether or not you need the long bed depends on the front cap / front end design of the 5er. I am ok to about 85* turning with mine. No slider hitch or anything else fancy.
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
All above are sold, no longer own an RV
goducks10
If you're buying a 2013-14 Ram 3500 DRW you will have no issues what so ever with payload. However if you're getting a 2012 or earlier you won't have the payload for a 14,000lb dry weight 5'er.
Can't help you on the short vs long bed issue.
Lantley
eHoefler
Look at the Ram Crew cab, the cab is not that much smaller than the Mega, but is available with the 8' box.
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
HappyKayakers
Instead of using the listed dry weight of your trailer, find the GVWR of the trailer. That will give you a more realistic picture of what you should buy to tow it. Most people use 15% - 20% of that GVWR to determine the hitch weight. A Dodge 3500 should have no problem pulling that BUT the limiting factor is usually payload of the truck. If you're near max weight of the truck when you get all your stuff and people in it, then add 1500lbs on the hitch, you could go over the truck's GVWR.
Joe, Mary and Dakota, the wacko cat
Fulltiming since 2006
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2017 Open Range 3X388RKS, side porch
loudounrv
byronlj wrote:
I drive in Colorado and several other Western states. After I bought my 40' fifth wheel I traded my shortbed for an 8' bed. The first drive on a winding mountain road confirmed I needed a long bed dually. Is the 14000# the dry weight of that 43 footer? If so, dry weight means little for towing information.
Dave
Hi Dave,
Yes, that's the dry weight of the trailer I'm hoping to buy. Are there any other specs I can add that would help? If I can't find them online, I'm sure I could get them from the salesman.
I'm pulling a 33' travel trailer now, and I've never towed a 5th wheel. Can you elaborate a little more on the mechanics of a short bed vs a long bed on those windy roads? Sorry for the simple question - I'm guessing that the long bed would let you take those turns a little sharper, right?
byronlj
Dave
byronlj
2013 Dynamax Trilogy 3800RL
kzspree320
I have no problem with my 6'4" bed and my fifth wheel. I have a Pullrite SuperGlide automatic sliding hitch. I drive it just like I was driving a long bed truck. When the turns get sharper, the hitch head automatically slides back for additional clearance. The only problem with a manual slider is that you must think about it and get out to use it before you need it. The SuperGlide will set you back a few more bucks, but I think it's well worth the piece of mind. Good Luck.
