itguy08
Aug 31, 2016Explorer
Dr Quick wrote:
My only comment is that the Ford 3.5 V-6 engine have an internal water pump, which if it goes, will be very expensive to replace. Like $1000 to $2000. Could also damage engine and engine would have to be replaced, as when pump goes, coolant can get into oil.
Have read on the internet of one engine failing at 61,000 miles due to pump failure.:(
Bzzt, wrong. The FWD applications (Taurus, Explorer, Flex) do have the internal water pump. The RWD (F150, Expedition) have an external water pump. Don't believe me? Look it up on fordparts.com
To the OP - we tow a 35', 9900lb trailer with our Max Tow Ecoboost. It does great. Make sure you get a good WD/Anti Sway hitch. We use the Equalizer.
44,030 PostsLatest Activity: Jan 20, 2025
