- Alabama_JimExplorerThanks for information. Last weekend it was about 82 degrees in Gulf Shores, AL. and low humidity. I could feel cool air coming out, but I thought under those conditions the ac would run you out if left on high.
- HalmfamilyExplorer2014 Dometic Brisk Air II units had a production issue and are failing after 12-16 months. Dometic is aware of the issue and is replacing the units under warranty.
- hohenwald48Explorer
Alabama Jim wrote:
What do you look for when the AC does not seem to cool the TT as it should. It is blowing cool air. The unit is a dometic.
What's it like outside? - fla-gypsyExplorerReplace the filter, clean the cooling coils, run it on max cool and high fan and do everything you can to prevent heat gain(close blinds, pick shady campsites, etc.) The air discharge should be 20+ degrees cooler than inside temperature.
- TodduptonExplorerYou look for the difference in the temp going in and the temp coming out.
About Travel Trailer Group
44,025 PostsLatest Activity: Feb 06, 2025
