DRSMPS
Jul 23, 2014Explorer
Air Conditioning Help - 2010 Sierra
During the last couple weeks, I've noticed that my truck's A/C isn't working as well as I remember in past summers. Symptoms are as follows:
1. When the truck is at idle, I can hear the compressor kick in and out often and it sounds much louder than normal. The compressor is louder and has a rattle-type noise only noticeable at idle.
2. When driving on warm days it intermittently blows really cold and then just "cool" depending on idle speed. It keeps the cab comfortable, but I recall it previously keeping the cab ice cold. I run it on high all the time, whereas I used to run it on low to stay comfortable.
I brought it into a NAPA dealer where we are staying to have them inspect it. It was in the morning when the temperature outside was around 75 deg. They measured the vent temperature at 58 deg and told me the system was OK. I asked if they could put gauges on the high and low side and advise me on the coolant pressures, but they said they didn't have the license to do so.
I'm debating taking it to a dealer with a licensed A/C mechanic. They advise that the diagnostic charge for this work is $120 though.
I'm looking for advice. Should I bring it to the dealer and have them check it out? - or - Should I pick up a can of R134A at my local parts store and one of those adaptors that lets me check pressure on the low side and top the system up myself for $25? Does it have to be R134A or can I use the Redtop "equivalent" coolant to top up the system? Does this sound like I am low on Freon or is it something more serious?
Thanks for your help and advice.
