For those of you that get off the beaten path with your truck/camper rig, I'm wondering if you can share what air pressure you typically air down to when needed? I have a 2006 F350 crew cab/short ...
If we are talking loose sand, then I air down the rear to around 35psi and the front to 30psi. You want the tire to have a good bulge so it gets wider.
