mikefos
Jun 15, 2020Explorer
Alpha Systems Alpha-ply TPO roof sealing
Howdy,
I was going to reseal the self-leveling sealant areas on my Alpha-ply TPO roof with Alpha Systems 1021 sealant, due to the surface cracking that you can see in the photos around the ladder and radio antenna . Alpha Systems recommends soap and water to clean the areas but that doesn't entirely clean-up the surface of the existing sealant, unless what I see left over is just discoloration. I also tried some denatured alcohol on one area and that didn't help either. The soap and water (Dawn) took care of the loose material on top of the sealant but you can see it is still discolored. Can I lay down the self-leveling sealant over the existing discolored sealant surfaces on the roof and be confident it will adhere (after going over with Dawn and water)? All areas of existing sealant are this color. I believe originally in 2012 when new, this material was white.
Thanks,
Mike
Thanks,
Mike
