- rexlionExplorerSome years back a good thread on the subject revealed that when going above 700 or so lbs of tongue weight the Andersen didn’t have enough leverage to level the rig. I used one for a couple years with a 2700 lb (350 hitch wt) TT and liked it (but it sold with the TT).
- TomG2ExplorerYou are probably one of those people who do not get to use an Andersen hitch. Too much tongue weight for it to handle well. The hitch works very well for smaller trailers towed with adequate tow vehicles.
- GrandpaKipExplorer III have 600# of tongue weight on an Andersen and wouldn’t go much higher. 1000# probably too much.
- goducks10ExplorerDepends on what you're towing with. I used one for a short period of time before getting a 5th wheel. I used it with a 2500 Cummins and a 900-950 lb TW TT. Worked great because I didn't need to return much weight back to the front of the truck being that the Cummins is way heavier than a gas motor. Front hardly lifted when hitched.
I previously towed the same TT with an F150 and needed 1200 lb bars to restore the front of the truck.
My thinking is I could've never made the Andersen work with the F150 but it was great with the 2500 CTD since it didn't need to transfer as much weight and the truck wasn't softly sprung like a 1/2 ton is.
Like mentioned above it seemed when they 1st came out and there were lots of trials with them that the heavier the TW and the lighter duty the truck the harder it was to make the Andersen work.
On a good note, it's a really nice looking hitch. :) - Ron3rdExplorer IIIThe Anderson has its application for lighter trailers but would be a poor choice for your trailer imo
- Prior_PeteExplorerThanks folks, sounds like Andersen is out. Now I'll look for recommendations. Equalizer? Dual Cam? Blue Ox? Others? Oh ya, towing with 2020 Silverado, crew cab, 6'5" box & max trailering package.
- afidelExplorer IIAny of the 3 you mentioned will do well, they're all available in appropriate weight ratings and pretty well regarded. The one thing I'll note is that the Equalizer head is not able to accommodate different weight bars so if there's a chance you'll downsize in the future keep that in mind (though honestly it's more of a consideration for those that are likely to move up in the future, I think a much smaller percentage of owners downsize significantly)
- fx2tomExplorerI LOVE the Equal-I-Zer hitch. Towed a 36 foot 8300 lb travel trailer with it for 6 years without a single issue. Easy to use and does a great job handling weight and sway. Short of going Hensley I wouldn't go with anything else for my use.
- lane_hogExplorer III've been using a Reese Dual-Cam on and off for 15 years. Love it, wouldn't be without it.
- Ron3rdExplorer IIIAll 3 will serve you well. I use the Equalizer
44,029 PostsLatest Activity: Jan 13, 2025
