May-11-2015 03:11 PM
Mar-03-2016 06:30 PM
Bob B wrote:
I also have a 2013 DRW Duramax that I want to do this to .... could you provide more details on how you did this .... could even do a new thread so we don't hijack this one.CAJW wrote:
You haven't filled out your profile so we don't know what year Duramax you're dealing with. I just finished installing a BlueSeas ACR and 50 amp breaker to keep the house and truck batteries tied together while the engine is running and separated when not. During that research I found my truck (signature) requires a 40 amp fuse in the aux 12v slot to charge your house batteries. You'll need to refer to your fuse schematic for the location of that fuse. If it was charging and now it isn't, that fuse would be the first thing I'd check.
Mar-03-2016 05:03 PM
Mar-03-2016 12:20 PM
Mar-03-2016 08:58 AM
Mar-03-2016 07:47 AM
Mar-03-2016 06:19 AM
07IDCLASSIC wrote:
So I'm having an issue now with my batteries not charging off my truck or I believe that is the issue anyways. Last time I had the camper on the truck the Happijacs wouldn't go down even with the truck running. I had to plug it into the wall to get them to work. I've heard there maybe a wire or a fuse on the duramaxes that you have to plug in or something. Last time we went out we went out for a couple days and ran the heat for a while and everything but then it was a solid 2.5 hour drive back so I figure the batteries should have been charged by then. These are new batteries too. I'm not near the truck or camper right now as I'm on the slope but trying to get some ideas as the gf wants to take the camper to Homer the day after I come off Slope. Thanks again for all the help guys!
Mar-02-2016 08:21 PM
Mar-02-2016 07:43 PM
Mar-02-2016 04:32 PM
May-25-2015 10:52 PM
May-25-2015 06:38 PM
07IDCLASSIC wrote:
Thanks guys for all the help. Ended up going with 2 group 31s from batteries plus. They just barely squeak in but they fit. Didn't have to turn the furnace on but went out for 3 nights and everything lasted great. Morsnow thanks for the heads up on the location.
May-25-2015 05:18 PM
May-25-2015 04:58 PM
May-12-2015 09:50 PM
07IDCLASSIC wrote:
Thanks for all the help guys. Really appreciate it. Morsnow we are in Anchorage. Doesn't look like there is a Batteries Plus except at the airport or out in Wasilla.
