โJun-12-2017 02:20 PM
โJun-14-2017 07:43 PM
ShinerBock wrote:
You are correct in terms of viscosity. From that data I have seen from Cummins, the only time synthetics is really needed is at colder temps. There is not much of a difference viscosity wise at hotter temps. For most that live in warmer climates, synthetic oil does not add any real benefit when it comes to viscosity to justify the extra cost.
โJun-14-2017 09:40 AM
LIKE2BUILD wrote:
The chart shows 5W40 good in all directions but 15W40 only good at 0*F and above. Technically, the only difference in the two should be viscosity at lower temps.
โJun-14-2017 09:31 AM
albow wrote:
Got to be a misprint on the upper temp range. So, the current recommendation for a Cummins is 15K, even when used for towing, i.e. severe duty, or are you stretching it out like me and only tow occasionally? Mine is a paltry 3,750 severe and 7,500 non severe
โJun-14-2017 08:29 AM
Lynnmor wrote:LIKE2BUILD wrote:
So, I just run Rotella T6 5W40 year 'round at 15K change intervals.
KJ
Of course you know that T6 has changed about six months ago. It now has reduced anti-wear additives and no longed is approved by Ford. When my old stock runs out, you can be sure that I won't run an inferior oil.
โJun-14-2017 08:28 AM
โJun-13-2017 11:09 PM
ktmrfs wrote:Yeah, primarily an older vehicle issue, but if you look at the article I linked, the diesel oils only have a minimally higher amount of zinc in the last several iterations to come out.
the lower zinc level is primarily an issue with flat tappet cams. Many, maybe most, of the newer diesels and cars run a roller cam, so it isn't as much of an issue.
Best thing to do is use a CK oil, not a CK SN oil. Since they aren't SN rated, they don't need to meet the lower zinc level.
But that is easier said than done.
โJun-13-2017 11:06 PM
LIKE2BUILD wrote:Got to be a misprint on the upper temp range. So, the current recommendation for a Cummins is 15K, even when used for towing, i.e. severe duty, or are you stretching it out like me and only tow occasionally? Mine is a paltry 3,750 severe and 7,500 non severealbow wrote:
...I don't know if the newer trucks require full synthetic or not or what the oil change intervals for them are (am interested to hear though).....I'm just curious....analysis figures from those who have had it done and the conditions the oil was run in would be nice to see.
My 2014 Ram manual gives a little conflicting information. The generic owners manual says to run 15W40. But, if you look in the diesel supplement it's a little different. There is a chart with arrows that shows 15W40 from 0*F and just points out past 32*F. But then there's another arrow for synthetic 5W40 that points below 0*F and beyond 32*F. I could be wrong, but I the Cummins equipped trucks ship with 5W40 in them.
KJ
โJun-13-2017 08:31 PM
โJun-13-2017 07:43 PM
albow wrote:FishOnOne wrote:These would be very hard to find and ck4 wouldn't even meet my 2003 engine requirements. I once ran an older formulation of diesel oil in my car for the zinc but as you will see in the linked article, there's not much you can do now and there are some drawbacks to the zinc and phosphorous as well as benefits. https://www.hemmings.com/blog/2012/10/18/tech-101-zinc-in-oil-and-its-effects-on-older-engines/
I would stay away from oils that have a dual rated diesel and gas ratings of API CK4 and SN which reduces the anti wear additives zinc and phosphorous. This would include Mobil Delvac and Chevron Delo.
At least until we see some UOA on these dual rated oils.
โJun-13-2017 05:21 PM
KJ
โJun-13-2017 02:21 PM
โJun-13-2017 09:06 AM
fj12ryder wrote:Glad to hear that. I wonder what difference it makes when an engine changes. For example, yours is 24v and mine is the first common rail. I wonder with each engine change if the results hold true, but I'll bet it changes some, making some more favored than others. I can't imagine anything being wrong with any of the major brands, just some a little better or able to go longer between changes than others.
I've used Delvac 1300 and Shell Rotella TTT in my 2001 Dodge Cummins, and always have gotten better reports from Blackstone Labs with the Delvac. So now I just use Delvac unless I have to get the oil changed on the road and they don't have Delvac.
โJun-13-2017 09:01 AM
WTP-GC wrote:I've seen Mystik advertised a time or 2. I always figured it was more of an expensive exotic like amsoil or royal purple. Good to know. Never heard of Schaeffers but glad you're happy with it.
Let me be the first to suggest a specific oil that I wouldn't run...MYSTIK (or MYSTICK)
I used this for a few oil changes in my older TV. When I ran oil samples, the results showed several unfavorable characteristics, such as poor viscosity, low flashpoint, etc. The report suggested that it would be fine for shorter change intervals (3000 miles or less). It was readily available and fairly inexpensive at a local fuel/lubricant dealer nearby.
These days, I only run Schaeffers in my diesel trucks.
โJun-13-2017 08:58 AM
Grit dog wrote:Yeah. I had no intention of changing after 200K, but did want to hear thoughts and hopefully oil analysis on various ones, particularly if someone said stay away from something more than anything with a valid reason.
Don't worry, it's as hotly debated here as anywhere.....lol. But you already knew that.
You seem to know what works for you and in the first half dozen posts were reccomended against that, that you've had good performance out of. So the answer is, keep changing your oil.....regularly!
