Sort By
- janglesExplorerThanks guys , problem solved , sold the camper !!
- whizbangExplorer IIYour propane tank ran empty???
More details please. - s1214Explorer"Depending on specific models, there are two things common to those 3 items, 12 VDC and propane. If either is missing they wont work.
Like he said. If your stovetop is working then you can rule out a propane issue. My old Sun-Lite's furnace and 3-way fridge would not work if the battery was removed or dead. - rexlionExplorerCheck your circuit breakers and LP supply.
- Mandalay_ParrExplorerCall a mobile tech if need be or find an electrical person to help you.
- jmckelvyExplorer
jangles wrote:
Truck camper fridge, heater and the hot water heater quit working all at once . What the heck would cause this ? Battery ? fuse / I'm lost . thanks for looking .
Can you provide more details? Are you plugged in to shore power or not? Does your cook top work? If so I would concentrate on the 12 VDC and make sure it is good. If not check for blown fuses, bad connections, run down battery, etc.
About Travel Trailer Group
44,031 PostsLatest Activity: May 15, 2025
